Enable SNMP on V1210
Hi leofran,
Information you provided is not enough to give you an answer.
Send your Master and Slave projects to support@unitronics.com.
Add detailed explanation of SNMP session, what other equipment accessing this OPLC at the same time, network diagram (switches, hubs, gateways, routers etc.), and what software do you use (if any).
What is VisiLogic version, versions of system files used by VisiLogic for each OPLC and versions of system files at each OPLC.
BR
