Dave Posted December 9, 2012 Report Share Posted December 9, 2012 Nothing really important.....just fustrating that I have a V570 screen full of butttons with two lines of text on each one, but the one I need passworded, I can't figure out how to get two lines. Is there a special character to insert or a key combination that I am unaware of? I am using a numeric password object, but I've noticed the same for string password objects too. Dave Quote Link to comment Share on other sites More sharing options...
Ofir Posted December 9, 2012 Report Share Posted December 9, 2012 Hi, As I understand you are using the display text - you can choose the option "string from Library" and then you can write the text in the string library and use the second icon from the upper left (insert carridge return line feed) for adding new line of text. Quote Link to comment Share on other sites More sharing options...
Dave Posted December 9, 2012 Author Report Share Posted December 9, 2012 Ah, yes. That will work fine. Thanks for the quick response. Dave Quote Link to comment Share on other sites More sharing options...
