russedwards Posted February 6, 2013 Report Share Posted February 6, 2013 Hi Is there a way to change the name of a file saved by Data Export? For example, my current schedule downloads the data from a data table after each complete test cycle is completed and the test finishes. Data Export then saves the data table to an Excel file named after the date and time of the download. Is there a way to change this so that the file is saved by another name (for example, a field within the data table). I would like to save each downloaded file by the serial number of the item that has just been tested. I hope this is clear! Thanks Russ Edwards Quote Link to comment Share on other sites More sharing options...
