Adriano Posted May 29, 2013 Report Share Posted May 29, 2013 Hi, I'm new user , I have this problem i must create a pin to pin cable for connect jazz to mj20-rs because the jazz is inside the machine and i can't put in my mj20-rs, so my idea is built the cable to connect jazz to mj20-rs. But the strip connector on board jazz has 10 pin, but for mj20-rs i can use only 4 pin but i don't know which. If possible know which pin i use for this Link to comment Share on other sites More sharing options...
AlexUT Posted June 2, 2013 Report Share Posted June 2, 2013 Dear Adriano, Sorry, but it is completely not allowed to make an “extender” between Jazz port connector and Jazz add-on modules. The signals on the Jazz port are low voltage and sensitive signals and all the add-on modules are isolated. Which Jazz model you’re using? How many machines like this you have? If your Jazz will have built in USB port, will this fix the problem? Link to comment Share on other sites More sharing options...
