klijo Posted June 20, 2013 Report Share Posted June 20, 2013 In the "Hardware configuration" IO-D16A3-TO16 for High Speed Output (PWM) are onli two parameters: Operand for Frequency MI - where is ML ? Operand for Duty Cycle MI - there is not MB for Run PWM ??? - How PWM works on IO? ** Configuration: V570, V200-18-E2B, IO-D16A3-TO1 I want to run three servo motors Quote Link to comment Share on other sites More sharing options...
AlexUT Posted June 20, 2013 Report Share Posted June 20, 2013 Hi, In accordance to specification of IO-D16A3-TO16, max. PWM frequency is 32K. MI is fitting this. You stop PWM by writting 0 frequency. *You should use slowest servo when connect to IO module. B.R. Quote Link to comment Share on other sites More sharing options...
klijo Posted June 21, 2013 Author Report Share Posted June 21, 2013 Thanks! servo speed is ok with electronic gear ratio (EDC Series AC Servo) I.K. (AutoGuru) :D Quote Link to comment Share on other sites More sharing options...
