Fabios Posted November 17, 2010 Report Share Posted November 17, 2010 Hi, i must start up 2 I/O LC3. On the manual http://www.unitronics.com/Data/Uploads/IO_expansions/IO-LC1%20IO-LC3.pdf on page 10 there is chart for Effective Resolution. Can you explain me this chart please? Ciao Fabio Quote Link to comment Share on other sites More sharing options...
Ofir Posted December 23, 2010 Report Share Posted December 23, 2010 Hi, The resolution stated in the graph, is the actual resolution. It depends on many factors. For defined sensitivity and time, the stated number is the real one. The other numbers in the result are not relevant – not precise. Quote Link to comment Share on other sites More sharing options...
