RNT_KCZ Posted September 10, 2013 Report Share Posted September 10, 2013 Hello, I've got a problem with the SEND block of the PROTOCOL FB's, I need to calculate the checksum according to CRC-16 algorithm with initial value 0x0000, but the only available option is CRC-16 (Modbus) where the initial value is 0xFFFF. Is there a way to change the initial value, or add this checksum algorithm? Another problem is the order bytes in the calculated checksum, maybe you could add an option to swap bytes? Link to comment Share on other sites More sharing options...
AlexUT Posted September 11, 2013 Report Share Posted September 11, 2013 Hi, Tell us about used VisiLofic version, PLC model, and Syatem files versions. Then we will provide you better advice. BR. Link to comment Share on other sites More sharing options...
RNT_KCZ Posted September 14, 2013 Author Report Share Posted September 14, 2013 Hi, I'm using V350-35-T38 ( PLC with O/S version: 3.007 (00) and VisiLogic 9.5.0 Link to comment Share on other sites More sharing options...
