tantalean Posted September 14, 2013 Report Share Posted September 14, 2013 I plan to use Windows Server 2008 platform to run Visilogic and connect to my PLC-HMI V1210. However, I got many errors installing and now running it (It worked fine under Window 7). I just managed to completed a "Hello" program. Then close Visilogic an opening to get another errror. Now I cannot even run it because the error message saying "DLL: UnPrHnd1." see the attached. Maybe Visilogic isn't meant for Windows Server (2008) and that is the reason. Please, Help. Quote Link to comment Share on other sites More sharing options...
AlexUT Posted September 16, 2013 Report Share Posted September 16, 2013 Hello, Unitronics software is Desctop OS oriented. Unitronics Support Download section: http://www.unitronics.com/support/downloads Includes Software system requirements, which is constantly updated: http://www.unitronics.com/docs/technical-library/software-system-requirements.pdf?sfvrsn=0 Server platforms are not supported officially, as them intended to run different software, like e-mail servers, data base engines etc. I hope this answers your question. Quote Link to comment Share on other sites More sharing options...
