mikewood Posted September 17, 2013 Report Share Posted September 17, 2013 I want to use strings for different languages. Currently I am using the set string FB, but once the unit is powered down and then powered back up, the string defaults back to the first string library, not the last selected one. Is there a way to set a string library that holds during power cycles? Thanks Mike Quote Link to comment Share on other sites More sharing options...
Alexander Posted September 30, 2013 Report Share Posted September 30, 2013 Thread moved to Software/ Vision PLC series and VisiLogic section. There is no default setting to power up to the last loaded string library, but it can be accomplished within the logic. Each time a string library is set store that specific libraries value (1, 2, 3, etc) into an operand reserved for last loaded library. Then upon power up always set string library indirectly using this direct operands value. In this way it should always load the last utilized library even after cycling power. Quote Link to comment Share on other sites More sharing options...
