kozemjaka Posted September 26, 2013 Report Share Posted September 26, 2013 Good day. I have a question about SB183: According to the help topic "How the Controller works with SMS messaging" - during sending SMS SB183 lasts about 5 sec. So If I manually organise a SMS sending I must manually organise SB183 ON five second delay (by means of Timer) and then switch SB183 OFF manually also, I`m right? OR this 5 sec are automatically organised in PLC and SB183 automatically switches OFF. Thank you for your answer in advance. MIke. Link to comment Share on other sites More sharing options...
Alexander Posted September 30, 2013 Report Share Posted September 30, 2013 Mike, When sending a message you only need to turn on the send MB that you linked within your application. SB 183 will automatically turn on by itself (which will generally take 5 seconds). Then after it is transmitted SB 185 or SB 184 will turn on relating to a fail or success respectively. Link to comment Share on other sites More sharing options...
kozemjaka Posted October 1, 2013 Author Report Share Posted October 1, 2013 Alexander, thank you for replay. About linked MB it is clear for me - all is done automatically, But in my case I receive the SMS from one (of five) phone, and I want to resend THIS SMS to ANOTHER phone from the phone list. As I understood using MB I will resend this SMS to both phones, but I need only to receive from one and only to send to another one? Or nevertheless it is better to use MB? Thanks for help in advance, it my first experience programming JAZZ. Image from Ladder: Link to comment Share on other sites More sharing options...
Alexander Posted October 2, 2013 Report Share Posted October 2, 2013 You can absolutely send an SMS message to another number after receiving the same message. It is not necessary to directly use SB's for this purpose as shown in your ladder image.This is described in more detail in the help file in U90 under Communications/ SMS/ SMS Message Properties. In the SMS Configuration you can link a specific message to both a send and receive MB. After the message is received the receive bit will go high. This can directly trigger the send bit which will send the message to all selected recipients within the SMS configuration. This will allow you to both receive a message, then immediately send it out again. Link to comment Share on other sites More sharing options...
