Raymno Posted October 16, 2013 Report Share Posted October 16, 2013 I need to share a data table across multiple V570 PLC's. Is this attainable? Can it be shared over UniCan? Link to comment Share on other sites More sharing options...
Gabriel Franco Posted October 17, 2013 Report Share Posted October 17, 2013 You could try MODBUS IP function read/write from/to data tables Link to comment Share on other sites More sharing options...
Raymno Posted October 17, 2013 Author Report Share Posted October 17, 2013 Gabriel, Thanks for the suggestion. I wasn't aware of this function and I'll look into the possibility. Currently, I do not have an open slot to put an Ethernet Card. I have 3 serial ports being used in my application. Port1 talks to a printer, Port2 talks to 7 servo motors and Port3 talks to 4 bar code readers. I was hoping to use the CanBus port as the PLC bus. Link to comment Share on other sites More sharing options...
Raymno Posted October 17, 2013 Author Report Share Posted October 17, 2013 Does UniStream afford any properties to act as a bridge in sharing Data Tables with V570's? Link to comment Share on other sites More sharing options...
Raymno Posted October 17, 2013 Author Report Share Posted October 17, 2013 Removed message Link to comment Share on other sites More sharing options...
