aeamsalomon Posted October 23, 2013 Report Share Posted October 23, 2013 When I try to open the UniLogic software, nothing happens. I tried reinstalling, but can't get it to work. I installed and reinstalled net framework and do not find a solution. This also happened to me with download manager. Many thanks for your help. Maxi. Quote Link to comment Share on other sites More sharing options...
Saragani Posted October 23, 2013 Report Share Posted October 23, 2013 Can I assume that you don't even see the splash screen? If so, then a small part of our users have experienced this issue, it has been addressed and it will be resolved on our next release. The issue happens because Windows is missing the registration of the .png file type. We believe that one program that you have installed or uninstalled, has removed the Content Type, or the png extension from the registered extensions on Windows. For fixing the issue by yourself, open regeit On HKEY_CLASSES_ROOT look for .png If you don't find it then add a new Key called .png Now, you might find the following string values under that key, and you might not. If you don't then create them, and if you do, then just change the value: Under that key, add a new String value, and give it the name: Content Type Right click it and choose Modify. Enter the value: image/png Add another string value, and give it the name: PerceivedType Give it the value: image It should look like the picture that I've attached. You don't need the "OpenWith.." etc (they are not required for UniLogic to run) Please tell me if it helped. Thanks. Quote Link to comment Share on other sites More sharing options...
