janst Posted December 3, 2013 Report Share Posted December 3, 2013 Hello, I´ve tried to import russian language string file to the string library, but I always get result texts like ??????. I´ve tried both excel and csv files (but Visilogic doesn´t accept csv file saved as unicode). I have Arial font installed in Visilogic and I´m able to write russian texts, but no import. It's difficult for me to type every single string in the russian, I don't know this language. Ctrl+C Ctrl+V doesn't work neither. It's the same in Visilogic 9.3.1 and 9.5.0. Its any way how to figure out this import? Quote Link to comment Share on other sites More sharing options...
mikewood Posted January 7, 2014 Report Share Posted January 7, 2014 Hello, I´ve tried to import russian language string file to the string library, but I always get result texts like ??????. I´ve tried both excel and csv files (but Visilogic doesn´t accept csv file saved as unicode). I have Arial font installed in Visilogic and I´m able to write russian texts, but no import. It's difficult for me to type every single string in the russian, I don't know this language. Ctrl+C Ctrl+V doesn't work neither. It's the same in Visilogic 9.3.1 and 9.5.0. Its any way how to figure out this import? I am very interested in the solution to this as well. Quote Link to comment Share on other sites More sharing options...
Ryan Posted January 7, 2014 Report Share Posted January 7, 2014 In the font handler, make sure that script is set to Cyrillic (box is at the bottom right) Also your PC should be set to Russian as well to allow the Copy/Paste. In Control panel --> Region and Language On the formats tab select Russian from the first drop down. On the administrive tab click "Change System Locale" Set the Default input to russian. You should now be able to copy and paste russian characters freely. hope that helps! Quote Link to comment Share on other sites More sharing options...
