kikep Posted December 19, 2013 Report Share Posted December 19, 2013 I have VSL 9,5,0 windows 7 32 bits, I can connect to plc and do evreything but after i close the project when i repoen it send this message error 438 object dont support property or method and block all, also every time when i start visilogic install smart gallil term alot 3 or more times. thanks. Quote Link to comment Share on other sites More sharing options...
Michael_P Posted December 20, 2013 Report Share Posted December 20, 2013 Hi Kikep, This sounds as though it may be a windows setting or the initial install of the software. Please try to re install the software in accordance with the following links Keep in mind you will need to run the software with administrative privileges as well as adjusting the UAC during and after instillation If you continue to generate the error, take a screenshot and send it to Support@unitronics.com http://forum.unitronics.com/index.php?/topic/694-how-do-i-perform-a-full-re-install-of-visilogic/ http://www.unitronics.com/docs/pdf/disable-uac-vista-win7.pdf?sfvrsn=2 Quote Link to comment Share on other sites More sharing options...
