390186 Posted January 2, 2014 Report Share Posted January 2, 2014 Hello, and recently that work on a v570j, I was able to load a saved project, but I can not load the project of ex-rc1 communication failure between PC and ex-rc1.between pc and OPLC via usb no problem of communication.who can help me?Sorry for my english Quote Link to comment Share on other sites More sharing options...
Michael_P Posted January 2, 2014 Report Share Posted January 2, 2014 390186, Can you try a lower baud rate, I have included a link to some troubleshooting tips to see if you can find a missing link. http://forum.unitronics.com/index.php?/files/file/33-troubleshoot-communication/ Quote Link to comment Share on other sites More sharing options...
390186 Posted January 4, 2014 Author Report Share Posted January 4, 2014 hello,I was able to communicate with the module ex-rc1 when it is disconnected expansion modules, with both usb and rs 232 (or even downloading done on it) the problem is when I connect the modules (2 IO-DI16, IO-5 ATC8).While OPLC with its port I / O Expansions communicates with EX-A2X (2 IO-1 and IO-RO16 AO6X)The problem is on the modules unfortunately the old ex-rc1 and the old V570 gone are the short circuit, very likely connected modules on the ex-rc1 even if the LED flashes will no longer be able to communicate with the new ex-rc1.Now we are providing for the replacement of 2 modules IO-DI16 and 5 modules IO-ATC8I also tried to connect the module IO AO6X to ex-rc1 without configuringand are unable to communicate via usb rs232When I installed the new modules will give you results of the operationthankssorry for my english Quote Link to comment Share on other sites More sharing options...
