mikec Posted February 24, 2014 Report Share Posted February 24, 2014 Hello, first time here. I'm looking to purchase a V130-J-TR34, But I have 3 questions. 1 - Can you accomplish a continuous jog of a stepper using the PTO, if so how is this accomplished? 2 - I have a analog input to close the loop to the stepper, what I want to do is move a slide to a position based on the analog input feedback? 3 - Did I pick a controller capable of meeting my needs? Thanks in advance Mike Quote Link to comment Share on other sites More sharing options...
Eyal Koren Posted February 25, 2014 Report Share Posted February 25, 2014 Hello, first time here. I'm looking to purchase a V130-J-TR34, But I have 3 questions. 1 - Can you accomplish a continuous jog of a stepper using the PTO, if so how is this accomplished? 2 - I have a analog input to close the loop to the stepper, what I want to do is move a slide to a position based on the analog input feedback? 3 - Did I pick a controller capable of meeting my needs? Thanks in advance Mike Hi Mike 1- Absolutely. It is actually pretty easy to configure. I attached a sample application (also available in Visilogic) for your convenience. The application was created for V350 but you can use it to understand the programming that need to be done. 2 - You can connect the input of the slider to the target of the stepper. By linearizing the signal from the slider you can create any jog configuration you like. 3- The controller you picked will meet your needs as you defined them in this post. If you don't need many I/O, you can purchase the V130-33-TR20 -12 DI instead of 22 and 6 DO instead of 8. I hope that helps... V350_PTO example plus Jogging.VLP Quote Link to comment Share on other sites More sharing options...
mikec Posted February 25, 2014 Author Report Share Posted February 25, 2014 Thanks Eyal. I appreciate the quick response and sample program, answers all my questions Quote Link to comment Share on other sites More sharing options...
