Interact Posted March 5, 2014 Report Share Posted March 5, 2014 Is it possible to export the STL-code from U90Ladder? (I'd like to compare two programs, or is this possible in some other way?) Quote Link to comment Share on other sites More sharing options...
Eyal Koren Posted March 31, 2014 Report Share Posted March 31, 2014 Hi, It is not possible to export the STL code. However, you can view the STL code by going to Window menu-->STL. This will present the code, and if you need access to the text itself you can take a screenshot and convert the image to text via 3rd party software. Quote Link to comment Share on other sites More sharing options...
