Serial modem be used as an rs232 port
I have a vision 570 that was programmed (by at least 3 persons from looks of code). Can't get Ethernet or modem config setups to work. Looked easy in webinar videos.. 2 ways in which will work on this 570 is the  USB port and the rs232 ports. If i can get the modem (airlink raven XT) set up right i can get this unit online remotely. (boss will be happy). The Airlink raven has this real nice webpage based config screen. I just need to know the setup for all the screens.  Speed, verbose, dtr, cts, TCP, handshakes and such.
I have got OK to come up on the sniffer screen when reboot and did have gibberish come up earlier on one setting when I used remote operator to request ID.
The visilogic does not like the modem for some reason (maybe because it needs the right initialize commands)
Thanks
  • 4 weeks later...
