dylan Posted April 1, 2014 Report Share Posted April 1, 2014 Hi can anyone help. my version of 9.6 will not install on properly on my laptop. just says "9 permission denied" i have put up a photo of the message. dylan Quote Link to comment Share on other sites More sharing options...
neurocyber Posted April 2, 2014 Report Share Posted April 2, 2014 Dylan Have you followed the directions that are posted at Unitronics in regards to version 7 and 8. I think this is the correct link http://forum.unitronics.com/index.php?/topic/664-can-i-use-visilogic-with-vistawin7/. I have windows 8 64 bit and Unitronics support got me up and running after we followed the aforementioned procedure. Have not had any problems with 9.6 (or any of the other software) on windows 8. Greg Quote Link to comment Share on other sites More sharing options...
dylan Posted April 2, 2014 Author Report Share Posted April 2, 2014 still not working... have loaded 9.6 but now just displays- Run-Time error 70 Quote Link to comment Share on other sites More sharing options...
dijkjan Posted April 23, 2014 Report Share Posted April 23, 2014 Open the program with RMB and select Run as administrator. Quote Link to comment Share on other sites More sharing options...
DanT Posted April 24, 2014 Report Share Posted April 24, 2014 I too had similar issues with setting up Visilogic in Windows 8. What I finally did , and got things to work was to change the security properties on the Visilogic.exe in the Main directory. Be sure you have Administrator Permissions C:\program files\unitronics\unitronics Visilogic_C\main ( yours may be slightly diffferent) Right click on Visilogic.exe goto Properties on the Dropdown First open the tab for Compatability and check off fo rWindows XP Mode and also click on the Change settings for ALL users. Second open the security tab examine the security settings for each user IF they doe not have FULL Controll as ALLOWED, edit the user to give FULL CONTROL I also did this to the Visilogic Version Swapper.exe Once I got this done. I used Visilogic Version swapper to setup the version , the program worked. I even managed to get 3 versions of Visilogic Loaded ( 9.5 9.6 9.7) and functional thru Swapper by making sure the Visilogic.exe security settings were changed. Another note : I also had to change my USB-Serial Adapter cable because the drivers for my other ones would not support Windows 8 ( Some Prolific Chip versions will not work with Windows 8) Ended up getting a cable that specified to was compatable with Windows 8 and it works Dan Thomas Quote Link to comment Share on other sites More sharing options...
