Marius2 Posted April 23, 2014 Report Share Posted April 23, 2014 Hello, Now iam working with naked V570 HMI and v200-18-E4XB snap module + expansion module IO-ATC8. I got some problems with IO-ATC8 analog inputs. In my setup iam use current transformer http://www.ecproducts.co.uk/productdetail.asp?cat=24&item=4&pid=2135. Current transformer output is 4-20mA , so IO-ATC8 range of data iam using is 3277-16383 hardware configuration "normal mode", tumbler settings for current aquistion. My goal is show current value in HMI display, but there are some probems. Real values i getting is 2027-4323 ( these numbers not evry time the same). One time after restart of PLC ( power on/off) i saw good range 3277-16383. But after another restar input values changed 2027-4323. I dont know what to do, because same type transformer working in another el. cabinet, it connected to HMI snap input, range 819 to 4095. It works but some times snap input not working properly ( after resets), then i need turn of plc and wait, after aproximetly 30min input starts work fine. Hardware setting adjusted for current input. I measure transformer output it works fine. Waiting for Help. Best regards, Link to comment Share on other sites More sharing options...
AlexUT Posted April 23, 2014 Report Share Posted April 23, 2014 Hi, Please update your link. It show error. If you continue to have difficulties - send your project to support@unitronics.com B.R. Link to comment Share on other sites More sharing options...
Marius2 Posted April 24, 2014 Author Report Share Posted April 24, 2014 Hi, Please update your link. It show error. If you continue to have difficulties - send your project to support@unitronics.com B.R. model of current transformer CS-SD420L Link to comment Share on other sites More sharing options...
Walkerok Posted April 26, 2014 Report Share Posted April 26, 2014 I would suggest putting an electrical meter in line with your CT and make double sure that you are actually putting out a 4-20ma signal and not something less. I use IO-ATC8 modules and CTs all the time. I tried to look up your CT but the link shows to be broken and was not able to see any information. Looking at the specs for the CT is says "nominal 24VDC required" It is entirely possible that when connected to the ATC8 the voltage in the loop is falling below your CT required minimom voltages. Keith Link to comment Share on other sites More sharing options...
