chavez Posted May 19, 2014 Report Share Posted May 19, 2014 Hy, I programmed scale belt system which integrates total flow from curent weight and time. I have some troubles with making cumulativ , becasue some ideas that I have implemented doesnt work well. For example i put signal on digital output for one kilo every time that value is changed ( i compare old value and new one to see if it is changed, and i store new one in register) Is there any better solution becasue this solution has one big problem. sometimes in my registry buffer error ocurres. thank You for help BR Quote Link to comment Share on other sites More sharing options...
Eyal Koren Posted May 20, 2014 Report Share Posted May 20, 2014 Hello Chavez, Please send your application and explanations about the system to support@unitronics.com. If you are not willing to share your application, please give as much information as possible regarding the system setup and your implementation. Quote Link to comment Share on other sites More sharing options...
