ahoover Posted June 10, 2014 Report Share Posted June 10, 2014 Has anybody else had issues with TON timers?? Several times I have seen where the timer seems to get stuck with the "out" bit ON. It's a very simple logic where the timers out bit is used as a N/C bit to activate the timer, thus the timer is constantly cycling. I have seen where the out bit goes high & stays high until I "Reset Retained Tags" in UniApps. This may have occurred after a new application was downloaded to the UniStream. I'm using latest version of UniLogic & have all OS files up to date on the UniStream. Thanks, Ahoover Quote Link to comment Share on other sites More sharing options...
Eyal Koren Posted June 12, 2014 Report Share Posted June 12, 2014 Hi ahoover, Please send the application (or a screenshot of the specific logic) to support@unitronics.com Quote Link to comment Share on other sites More sharing options...
ahoover Posted June 13, 2014 Author Report Share Posted June 13, 2014 Eyal Koren, At the time of this issue I had been in contact with support & they looked at the logic. After tinkering with the issue for a while we found that resetting the retained tags takes care of it. Since support had never heard of this issue previously, I thought I would post on here to see if anybody else ever saw this problem. Thanks, ahoover Quote Link to comment Share on other sites More sharing options...
