lluisot Posted August 22, 2014 Report Share Posted August 22, 2014 Visilogic have the fifo function? Quote Link to comment Share on other sites More sharing options...
EduMarg Posted August 25, 2014 Report Share Posted August 25, 2014 Hi. There is no build in FIFO funtion on VisiLogic, but doing FIFO is possible. There is an example under the help menu/example/V570_vector_fifo This examples shows you how to created a FIFO logic. V570_Vector_ FIFO.vlp Quote Link to comment Share on other sites More sharing options...
lluisot Posted August 25, 2014 Author Report Share Posted August 25, 2014 Hi. There is no build in FIFO funtion on VisiLogic, but doing FIFO is possible. There is an example under the help menu/example/V570_vector_fifo This examples shows you how to created a FIFO logic. Thanks from Spain Quote Link to comment Share on other sites More sharing options...
