MVP 2023 Flex727 Posted September 12, 2014 MVP 2023 Report Share Posted September 12, 2014 I have a V570 PLC out in the field that needs to have some code updated. The original project, which I have, was generated using Visilogic 8.6.3. The firmware on the PLC is the firmware associated with Visilogic 8.6.3. I am currently using Visilogic 9.7.9 and no longer have 8.6.3 installed. Can I update the code in Visilogic 9.7.9 and generate a .V57 file to be delivered via the SD card, or do I need to re-install 8.6.3 to ensure compatibility with the older firmware? Link to comment Share on other sites More sharing options...
Michael_P Posted September 12, 2014 Report Share Posted September 12, 2014 Hi Flex, You have 2 options, you can Download the previous version and use Version Swapper. https://unitronics.exavault.com/share/view/4lk6-5yavn87c You can also update the application the the newest version and use a UniDownloader file that has the firmware included(OS,BIN,Boot) http://www.unitronics.com/support/webinars/downloading-utilities Either method will be sucessfull. Mike Link to comment Share on other sites More sharing options...
