Jstephens1967 Posted September 29, 2014 Report Share Posted September 29, 2014 Hello all, I'm new to these components and the forum and looking for advise. Any help would be greatly appreciated. First off I received a unit that was supposed to be pre-programmed, but it was not so I finally got programmed. My problem is that it is supposed to fire the relays every 28 seconds and it does not. I can access the menu and fire the relays "manually" but I can't figure out why program is not working. Any advise/troubleshooting tips for a newbie?? I'm thinking that the initialization string maybe wrong...just not sure what I'm looking at to tell. Thank you in advance for any and all help. Quote Link to comment Share on other sites More sharing options...
Eyal Koren Posted October 1, 2014 Report Share Posted October 1, 2014 Hello all, I'm new to these components and the forum and looking for advise. Any help would be greatly appreciated. First off I received a unit that was supposed to be pre-programmed, but it was not so I finally got programmed. My problem is that it is supposed to fire the relays every 28 seconds and it does not. I can access the menu and fire the relays "manually" but I can't figure out why program is not working. Any advise/troubleshooting tips for a newbie?? I'm thinking that the initialization string maybe wrong...just not sure what I'm looking at to tell. Thank you in advance for any and all help. Hi, Please send the application to support@unitronics.com and describe exactly what you want to achieve. Quote Link to comment Share on other sites More sharing options...
