pecos_maui Posted October 1, 2014 Report Share Posted October 1, 2014 Aloha all, I recently acquired the following and have connected them in the following order: Model V120-22-UN2, HW Rev A, OS Version 4.00(18), Vision FONTS - V1.3 (B00) 0 - EX-A2X expansion adapter 1 - IO-AI8 8 analog inputs 2 - IO-ATC8 8 analog inputs / 8 thermocouple inputs 3 - IO-AO6X 6 analog outputs 4 - IO-RO8 8 relay outputs 5 - IO-TO16 16 transistor outputs 6 - IO-R08 8 relay outputs When attempting to configure the HW / IO modules, the first module in the list IO-AI8 is no where in the list. Why is this module omitted from the list? The plc connects and communicates just can't get the HW configured as I need to. Any help is appreciated. Quote Link to comment Share on other sites More sharing options...
Eyal Koren Posted October 1, 2014 Report Share Posted October 1, 2014 Hi Pecos_maui, In the hardware configuration window, both the IO-AI8 and IO-ATC8 are being defined from the same icon. See attached image. Quote Link to comment Share on other sites More sharing options...
pecos_maui Posted October 1, 2014 Author Report Share Posted October 1, 2014 Thanks for the info. I looked at my configuration window at the module list and found that my version does not list the IO-AI8 as shown in your graphic (IO-ATC8 / IO-AI8), it only shows IO-ATC8. I've assigned slot 0 IO-ATC8 it appears to accept it. I believe that I downloaded the latest firmware for my PLC. Should I be looking for more updates to, match what you see? Quote Link to comment Share on other sites More sharing options...
