Gugulanov Posted November 7, 2014 Report Share Posted November 7, 2014 Hi there, I'm using V1040 with SD card, on which i'm storing .udt files. I want to use SI64 as reference for changing the current sub DT(1-4) folder when it is full.In the ladder application i'm using SB341 as condition for storing SI64 in a MI, but as result SI64 give me the remaining files in main DT folder, not in current sub DT folder (1-4), which i'm using. Did anyone faced the same problem? Regards Quote Link to comment Share on other sites More sharing options...
Alexander Posted November 7, 2014 Report Share Posted November 7, 2014 SI 64 will only calculate the number of files in the main DT folder. To know when a subfolder is full you will need to implement a counter each time a file is added to any SD card subfolders. Quote Link to comment Share on other sites More sharing options...
Gugulanov Posted November 10, 2014 Author Report Share Posted November 10, 2014 SI 64 will only calculate the number of files in the main DT folder. To know when a subfolder is full you will need to implement a counter each time a file is added to any SD card subfolders. Hi. Aham, okay. Meanwhile, i did it in a similar way, that you suggest. I used "Folder report" function with a counter.... Thanks for answer. Regards Quote Link to comment Share on other sites More sharing options...
