zaspany Posted November 18, 2014 Report Share Posted November 18, 2014 hello I read for modbus float (weight). But how change this float to integer? S Quote Link to comment Share on other sites More sharing options...
Eyal Koren Posted November 18, 2014 Report Share Posted November 18, 2014 Hi zaspany, You post raise a question: The Jazz and M90/91 products does not literally have a floating point data types, therefore it is not possible to read float registers, and sure not to convert them to integers. Please explain the issue thoroughly and if possible send the application. Quote Link to comment Share on other sites More sharing options...
