Apollas Posted December 15, 2014 Report Share Posted December 15, 2014 Hello, When I open a project or close Hardware configuration I'm getting a message that says: prvChangeGuiByPLCType 9Invalid Tools collection index (attached). I'm new to Unitronics and I have no idea what's wrong. Thanks for your help. Regards, Giedrius K. Quote Link to comment Share on other sites More sharing options...
Eyal Koren Posted December 15, 2014 Report Share Posted December 15, 2014 Hi, Please follow these instructions: Note that you need to install the software while the Windows UAC is OFF and after rebooting the PC. (VisiLogic V9.7.24 recommended) Turn OFF Windows UAC. 1. Delete the file Current_OPLC.udb from: C:\Program Files\Unitronics\Unitronics VisiLogic_C\Data\DB 2. Backup you projects and delete all the files related to Unitronics installations. 3. Erase the “Unitronics VisiLogic_C” folder from- C:\Program Files\Unitronics 4. Erase the “Unitronics” folder from- C:\Program Files\Common Files. 5. Perform Windows update and restart the PC 6. Log-on as administrator Save the setup file on your desktop and make sure that the installation file is not blocked (Right click on the file>Properties) If yes, just click on the unblock button: Install VisiLogic. If software opened properly, Go to the properties of VisiLogic shortcut and under compatibility ticked verify the Privilege Level “Run this program as an administrator”. Quote Link to comment Share on other sites More sharing options...
Apollas Posted December 16, 2014 Author Report Share Posted December 16, 2014 Thank you. Looks like it worked, but I need a little bit more time to be sure that is really OK now. It really sounds a bit complicated as just for the normal program installalation Quote Link to comment Share on other sites More sharing options...
Eyal Koren Posted December 16, 2014 Report Share Posted December 16, 2014 Thank you. Looks like it worked, but I need a little bit more time to be sure that is really OK now. It really sounds a bit complicated as just for the normal program installalation In normal installations this is not needed, and in most cases this process can be much shorter. However, it is better to take the longer path to a guaranteed success Quote Link to comment Share on other sites More sharing options...
