Stavros Posted December 19, 2014 Report Share Posted December 19, 2014 Hi, Can I establish master-slave communication between Jazz with rs485 module and a V570 PLC?V570 master / Jazz slave Thank you. Quote Link to comment Share on other sites More sharing options...
Ofir Posted December 21, 2014 Report Share Posted December 21, 2014 Hi, The answer is definitely yes. As both Jazz and V570 can perform as MODBUS RTU master or slave and both support RS485 you can establish MODBUS communication. Please note that for the Jazz you will have to use the add-on module JZ-RS4 (for RS485 port). Quote Link to comment Share on other sites More sharing options...
