nettron2 Posted January 22, 2015 Report Share Posted January 22, 2015 Hi All, Need Some Guide From All For My Latest Project. I'm Really Interested To Use Unitronics (Never Use Before). This Is My second Rotary Cutting Machine Machine. Previously Used Keyence (KV-Nano) CPU. Can Anyone Help To Propose Unitronics System Hardware/Configuration? Process Summary Line Driver Encoder; To Measure Steel Wire Length, Then Give Signal To Servo To Start Cut. Thanks Link to comment Share on other sites More sharing options...
Eyal Koren Posted January 22, 2015 Report Share Posted January 22, 2015 Hi Nettron2, There are several products that are suitable for the suggested project. To narrow the results please provide more information, such as: 1. Besides the components mentioned, are there any more I/O's in the system? how many? for Analog I/O's, what's the required measurement resolution? 2. What is the frequency required for the encoder? 3. What is the requirement for the user interface? Unitronics has several display sizes, color/monochrome, touch display/keypad. 4. Does the signal for the servo is a simple switch, or is it a HSO? 5. Are there any requirements for communication ports? In the meantime, I would recommend the Vision V350. This model consist of a 3.5" color touch display with built in I/O points, built in alarms screens and trends, several communication features, auto-tune PID, data logging to SD card and more. For the product page press here Also see comparison table in the attached pdf v350_comparison.pdf Link to comment Share on other sites More sharing options...
