Absolute Posted February 28, 2015 Report Share Posted February 28, 2015 We have an application that monitors an oven. We define a total cycle time from a user input, between 3 minutes and 4 hours. Then we start both a timer set to the user input and a timer that counts to 10 seconds and resets over and over. The user input value timer will end the cycle and the 10 second is to make a printer print time (hour:min:sec no date) and current temp. The problem we are having is that if we start the cycle at 1:36:00 the 10 second interval prints will not consistently show times that are ten seconds apart! we might get 3 lines with 10, 20, 30 but then it will show 41 or maybe 39 as the next seconds value, then after 3 or four times ending in the +1 or -1 seconds value it will go back to the original ends in 0 values. This will repeat over and over again during a long cycle happening between 17 and 19 lines between + or - 1 and it lasts between 3 and 5 lines before reverting. Are we trying to do something that the clock can't really do to an accuracy of one second? Quote Link to comment Share on other sites More sharing options...
Walkerok Posted March 3, 2015 Report Share Posted March 3, 2015 Can you post the part of your program that makes the print every 10 seconds? You should be able to use the RTC/UTC to get your prints to very regular, but I am a bit confused why the prints are not OK with just a regular timer. You could also try using just an increment function using the positive edge SB3 as the pulse. Every10 pulses print and reset the MI you chose and the increment storage location as long as you have a heating process in effect. Reset the MI to 0 whenever the heating process times out as well. Keith Quote Link to comment Share on other sites More sharing options...
cantcliff Posted March 4, 2015 Report Share Posted March 4, 2015 What are you scan times for the entire program in milliseconds? It seems insignificant but depending on the order of execution within the PLC for I/O, communications, and display elements you might be running into an issue with how the ladder is actually being traversed from scan to scan and displaying the data. Quote Link to comment Share on other sites More sharing options...
