Hello,
I am beginner with these controller and wanted to ask maybe is some examples or information about Data tables which are using inputs/outputs (analog & discrete) to control object ? Working with outputs/inputs examples would be good too.
I want to make fully controllable program there you can edit/use data tables for real objects using SD card.
Hello,
If you are unfamiliar with VisiLogic I would recommend watching our series of webinars online which can be found on our support page.
http://www.unitronics.com/support/webinars
Also, there are many sample project examples within VisiLogic. These examples can be found within VisiLogic by navigating to the Help menu and selecting Examples then Version 900\ Project Examples\ Data Table.
