Jerther Posted April 30, 2015 Report Share Posted April 30, 2015 Hi! I have a vlp project here on which I activated the simple web server. Here is what I get: http://screencast.com/t/CiE2gO3i8ST As you can see, sometimes it works, sometimes partially, sometimes it starts a downloads and sometimes it shows garbage which seems to come from some datatable. I also tried to change the socket binding to port 8080 with no change. Turning the PLC power off and on again doesn't change anything either. If I start a new project and only activate the web server with a single page, it works fine. I've attached the web server config. The PLC is a: V130-33-T38 rev. A OS: 3.9 (06) Any idea what could cause this? Quote Link to comment Share on other sites More sharing options...
Jerther Posted April 30, 2015 Author Report Share Posted April 30, 2015 Found it. I had the same socket initialized for MODBUS elsewhere... Quote Link to comment Share on other sites More sharing options...
