edit response timeout in modbus master
Within the Modbus Master configuration, each read/write command is periodically triggered using the period value defined in the configuration.
If the period is set to 100ms it should automatically attempt to reconnect and send the command using this value. Is there a reason that it would need to be dynamically changed?
There is an optional active bit for each individual command that would allow you to enable/disable commands using any ladder or timers.
