CAD drawings
Mare
Hi Mare,
Can yo explain more detailed your idea. It seems interesting, bu I'm not sure I fully understand it...
I have a AutoCad Electrical 2010 for drawin electrical shemes.There is one of options to select a different PLC-s from different Manufactors.When you select for example a PLC from Siemens you have options to select LOGO or Simatic or S5 Series.....Then you cen select the type and when you confirm those parameters you have a full lerminal list (component) in your drawing.Now you need yust to draw wires and connect it.
Drawing1.pdf
