morganhunter Posted June 21, 2015 Report Share Posted June 21, 2015 I am using a IO-D16A3-RO16 and have 3 flow sensors I need to attach, I have two attached to the HSC and want to know if possible and how to do it, is connect the other flow sensor up to a standard digital input? The flow sensor can give a max pulse rate of 73.33 pulses per second. Link to comment Share on other sites More sharing options...
s.pratt Posted June 22, 2015 Report Share Posted June 22, 2015 Hello, The response time of the normal digital inputs are 10ms. Therefore, we do not suggest attaching a device that has a frequency of 50Hz and above. Anything over 50Hz, you will run the risk of missing pulses. Hope this helps. Link to comment Share on other sites More sharing options...
