HNZ_Automation Posted June 28, 2015 Report Share Posted June 28, 2015 Hi VisiLogic 9.7.09 will not connect to any of my PLC's over Ethernet, it just displays the screen below. Any thoughts?? Quote Link to comment Share on other sites More sharing options...
Alexander Posted June 29, 2015 Report Share Posted June 29, 2015 Run-time errors are usually generated with our software when the program is not run as an administrator. Was VisiLogic recently installed or upgraded? To run the software as an administrator for Windows Vista, 7, and 8 use the following steps: · Close DataXport · Right click on the VisiLogic.exe icon and select properties · Navigate to the Compatibility tab · Select the box for Run this program as an administrator, and select apply · VisiLogic can then be opened with the new settings Quote Link to comment Share on other sites More sharing options...
