haysenergy Posted July 7, 2015 Report Share Posted July 7, 2015 I have a project were I am using an Enfora GPRS modem to make IP calls back to a web connected machine. This works very well and I have set it up to receive text messages via GSM. I want to use the received text to trigger a call back on GPRS to an IP specified in the text. I have found the function to convert the IP to a text but not text to IP. Is there one? If not how is the decimal storage of an IP formatted so I can do via math / string functions? Thanks in advance Andy Quote Link to comment Share on other sites More sharing options...
AlexUT Posted July 7, 2015 Report Share Posted July 7, 2015 Hello Andy, Tell more about PLC model you use.. Then answer will be more detailed. B.R. Quote Link to comment Share on other sites More sharing options...
haysenergy Posted July 8, 2015 Author Report Share Posted July 8, 2015 The model is a V570-57-T20B-J with a V200-18-E1B snap in module. I have an Enfora modem connected to Port 2 and the code for GPRS call back to my fixed IP is working perfectly and the SMS receive is fine. I just want to specify the IP address of the call from the content of the SMS text. The ip address is stored as a decimal in the FB so I need to convert the received text to the correct decimal value to put into the call FB. Best Regards Andy Quote Link to comment Share on other sites More sharing options...
