inatci1i Posted July 7, 2015 Report Share Posted July 7, 2015 hi i want to know can i use all analog input 4-20ma of jz20- r16 thanks Link to comment Share on other sites More sharing options...
s.pratt Posted July 7, 2015 Report Share Posted July 7, 2015 Hello, On the JZ20-R16, there are 4 analog inputs. Two inputs may only be used for 0-20/4-20mA signals, and there other two may only be used for 0-10VDC signals. Do you need all 4 to be for 4-20mA signals? Link to comment Share on other sites More sharing options...
inatci1i Posted July 7, 2015 Author Report Share Posted July 7, 2015 i need 1 0-10v 3 4-20ma thanks for replay Link to comment Share on other sites More sharing options...
s.pratt Posted July 7, 2015 Report Share Posted July 7, 2015 Would the M91-2-R6C work for you? -6 Digital Inputs (1 HSI) -6 Analog Inputs (2 are 0-10VDC/4-20mA, 4 are 4-20mA) -6 Relay Outputs Link to comment Share on other sites More sharing options...
inatci1i Posted July 7, 2015 Author Report Share Posted July 7, 2015 i know but i want to learn jz20-r16 provide my need thanks Link to comment Share on other sites More sharing options...
Walkerok Posted July 10, 2015 Report Share Posted July 10, 2015 Just use the 4-20ma sensor devices on one of the 0-10Vdc inputs by placing a 250 Ohm resistor between PLC terminal 4 (i6-7) and terminal 8 or 9 (i6 or i7)(whichever one you chose to put the 4-20 device on). This will give you a 1-5 volt input from a 4-20ma output device. Or a 500 ohm resistor will give you a 2-10v signal from a 4-20ma device. you would scale the input the same way you would a regular 4-20ma device if you use the 500 ohm resistor. Thanks Keith Link to comment Share on other sites More sharing options...
