Specifisaurus Posted July 8, 2015 Report Share Posted July 8, 2015 Hi All, Came across something that may be an issue, unless I'm misapplying it. The Sort Array function seems to shift the array contents back and forth (ascending descending) each time its sorted. Meaning one time it moves it one way, the next time its sorted it moves it the other way. I've included a couple of screen shots to illustrate what I'm talking about as the program itself was too large to attach. The array is 10 bits in length, one of the interesting things is if you have less than 5 bits active, the sort function seems to sort everything one way. When you have 5 or 6 bits active it flops back and forth as mentioned above, when you have more than 6 bits active it sorts everything the opposite way. This is all regardless of what is selected for the ascending or descending option. Link to comment Share on other sites More sharing options...
s.pratt Posted July 13, 2015 Report Share Posted July 13, 2015 Hello, We have tested and verified your results. We apologize for the inconvenience. The bug will be fixed in the next release of UniLogic. Link to comment Share on other sites More sharing options...
