DanT Posted August 17, 2015 Report Share Posted August 17, 2015 HI; Any one had experience with the CPU RS485 Port with regard to workmode Protocol (Com1)? The behavior and set up for data receive is different than using the USB ports on the HMI for 3rd party protocols If you have an actual working program, , can you post the COM Secton. Dan Quote Link to comment Share on other sites More sharing options...
