viper_lasser Posted September 8, 2015 Report Share Posted September 8, 2015 Why I must wait to long time to format my 8GB card with Unitronics SD Card Formatter ? I have another problem with card. In V1210 OPLC SB217 is not set on true after formatting and installing card in OPLC. What can be reson ? Link to comment Share on other sites More sharing options...
Saragani Posted September 9, 2015 Report Share Posted September 9, 2015 Hi, about the long time formatting: Which version of SD Card Suite are you using? The format tool is using a Windows API that was working fast on XP, but from Vista and onwards the format became very slow. At some point (in mid 2013), I've changed one of the flags sent to the API, which should make the format fast (tested here few times). However, if you still suffer a slow format, then you can use the option to "format drive using Windows", which should load Windows format dialog, and after it finishes formatting, the SD Card formatter would create the relevant directories. Link to comment Share on other sites More sharing options...
viper_lasser Posted September 9, 2015 Author Report Share Posted September 9, 2015 Today I changed SD Tool Formatter from 1.0.14 to 1.0.16 installed with SD Card Suite 2.0.58 and now everything is ok. Link to comment Share on other sites More sharing options...
