DC Joe Posted October 2, 2015 Report Share Posted October 2, 2015 Dear All, Alarm status viewer is great option, but .. Is it possible to retain status "DISABLE" after power loss? Are there any system bits that can make this possible? Kind regards, Quote Link to comment Share on other sites More sharing options...
DC Joe Posted October 5, 2015 Author Report Share Posted October 5, 2015 Problem is : when I disable ALARM, after reseting PLC, ALARM is enabled again? Quote Link to comment Share on other sites More sharing options...
Alexander Posted October 5, 2015 Report Share Posted October 5, 2015 The alarm would be activated again if the condition is true. The user would need to then manually disable the alarm if the condition is still active. Quote Link to comment Share on other sites More sharing options...
DC Joe Posted October 9, 2015 Author Report Share Posted October 9, 2015 The alarm would be activated again if the condition is true. The user would need to then manually disable the alarm if the condition is still active. Maybe I did not realized the point. I realized: If I have programmed ALARM, but don't want this ALARM to be active than I disable this ALARM in alarm management. Obviously, this is not the point. Kind regards Quote Link to comment Share on other sites More sharing options...
