dan_lorentz Posted October 15, 2015 Report Share Posted October 15, 2015 Is there a way to see thru the PLC (V130 for example) what the jumpers are set at for analog inputs. I believe using a simple SB to indicate voltage or current could be beneficial for OEMs that use lots of PLCs. Thoughts? Quote Link to comment Share on other sites More sharing options...
Alexander Posted October 15, 2015 Report Share Posted October 15, 2015 Currently all jumper settings have to be verified visually on the circuit board of the PLC. If this is a feature that you are interested in please send an feature request to support@unitronics.com so we can pass it along. We always are interested in hearing feedback and new features that you or your customers are interested in seeing. Quote Link to comment Share on other sites More sharing options...
