RDeVries Posted October 15, 2015 Report Share Posted October 15, 2015 Hello, I am new to this forum. I have a V1040 Unitronics and I am looking to use a scanner to load a part number resulting in a recipe parameters loaded. I see the port that is used on the V1040 is an RJ-11. I am trying to find a scanner that will work via RS-232 with an RJ-11 Jack. I haven't had much luck. Can someone point me in a direction of a Scanner they have used in the past? Thanks!!! Link to comment Share on other sites More sharing options...
DanT Posted October 16, 2015 Report Share Posted October 16, 2015 Hi We have these bar code scanners connected to V1040's in our shipping dept Motorola DS9028 RS232 to go into the PLC's - V1040's Com 2 Very flexible in codes being read. We use standard codes and 2 dimensional Q codes. Reliable. Dan Thomas Link to comment Share on other sites More sharing options...
RDeVries Posted October 16, 2015 Author Report Share Posted October 16, 2015 Dan, Thanks for your response. I assume you get the model with the RS-232 communication cable and the external power supply? Link to comment Share on other sites More sharing options...
DanT Posted October 19, 2015 Report Share Posted October 19, 2015 Hi; Yes, Be sure you get the RS232 Model and Power supply. Also get and extra programming cable RS232-CB1 to connect to Com 2. Dan Thomas Link to comment Share on other sites More sharing options...
RDeVries Posted October 20, 2015 Author Report Share Posted October 20, 2015 Thanks Dan, I just recieved my scanner and am going to work on getting it talk with the V1040. Link to comment Share on other sites More sharing options...
