dan_lorentz Posted October 19, 2015 Report Share Posted October 19, 2015 Under the COM Init block there is only one option for CDMA that is supported by Untironics, is this still accurate? With Verizon's network being CDMA does this mean there is only one modem that can be used on it? If so does anyone have information on the modem itself as I can't find anything online for a Konder modem. Thanks, Dan Quote Link to comment Share on other sites More sharing options...
Alexander Posted October 23, 2015 Report Share Posted October 23, 2015 Unfortunately it is not currently possible to use a serial CDMA modem with the Vision Series units. I will pass this along to our team so that there will not be any further confusion. However, an Ethernet modem that uses CDMA can be used as the controllers Ethernet port does not require any specific method of obtaining a connection to the internet. Quote Link to comment Share on other sites More sharing options...
