ORSO2001 Posted December 2, 2015 Report Share Posted December 2, 2015 Dear All, searched in the forum but I don't found what I need...and I can't insert a pic of the "question"..I can upload only 29.9 Kb! I tried to use the element "modbus read builder" to read a lot of registers together... in the point "A" I insert an "modbus request" with: protocol=0; function n°=3; slave ID=1; start address=0; number of operands=39; ethernet trns.= nothing. in the point "B" I insert a BUFFER (that I created in GLOBAL tag) with 8 "array". In the point "D" I insert a "modbus request descriptor" with: expected response=43 (I have read it after the first test...and is what I expected...if I have understood the modbus RTU protocol); protocol=0;function=3; start address=20; number of operands=19; ethernet=nothing. For the point "C" (request size) I tried different "tag" (buffer, int,uint..) but nothing seems work! When I tested the "program" I have had the following response from the buffer in the point "B": 1,3,0,0,0,39,5,208. in the tags that I tried to use for the answer (it is an answer?) I have always "0" in each point... What I have to do? thanks in advance Quote Link to comment Share on other sites More sharing options...
ORSO2001 Posted December 4, 2015 Author Report Share Posted December 4, 2015 Dear All, yesterday I have downloaded the last sample programs from the site and I understand that I really wrong everything...please accept my apologise if I have wasted your time with my uncorrect question...I am less then a beginner and I have learn more...now I know that I have to insert a tag with indicate the array lenght in the slave session and what I have tried before is for the TCP. I hope next time my question will be done in a properly way. Thanks Quote Link to comment Share on other sites More sharing options...
