jmlopez Posted December 22, 2015 Report Share Posted December 22, 2015 Good morning, I new on this forum and Unitronics, I need some help to set up my communication between my OPLC V570 to my drive Yaskawa V1000, I want to start sending start / stop commands from my V570, If some one has an example it will help me a lot. Quote Link to comment Share on other sites More sharing options...
s.pratt Posted December 22, 2015 Report Share Posted December 22, 2015 Hello, How do you wish to communicate to it? Do you know the protocols it supports? Are you planning to connect serially, via Ethernet, CANbus, etc... Please note, VisiLogic contains many example application via the "Examples..." option under the help tab. Quote Link to comment Share on other sites More sharing options...
jmlopez Posted December 22, 2015 Author Report Share Posted December 22, 2015 I want to communicate using the Modbus, the RS485 Quote Link to comment Share on other sites More sharing options...
s.pratt Posted December 22, 2015 Report Share Posted December 22, 2015 There is an example of using Modbus RTU in the "Examples.." of VisiLogic. (Version 900/Project Examples/Communications/MODBUS/V130_Modbus_Master) Also, we have a tutorial video on setting these communciations up here. You may download the example applications from this web page as well. Please let me know if this helps. Quote Link to comment Share on other sites More sharing options...
RobertU Posted December 28, 2015 Report Share Posted December 28, 2015 Hi, I recently made a program to change v1000 parameters directly from V570 - if you're interested PM Quote Link to comment Share on other sites More sharing options...
Langeman Posted March 4, 2021 Report Share Posted March 4, 2021 On 28-12-2015 at 8:23 AM, RobertU said: Hi, I recently made a program to change v1000 parameters directly from V570 - if you're interested PM Hi Robert. If you still have it. I would like to look at your program for changing parameters of the v1000. Quote Link to comment Share on other sites More sharing options...
