Mit Selihc Posted January 15, 2016 Report Share Posted January 15, 2016 Hi, Im having trouble understanding the wiring requirements for the UID-0016R. Am I correct in thinking that I should run a wire from the CM point to every Output in the group? Then run a wire from each Output to the appropriate relay? Many thanks Quote Link to comment Share on other sites More sharing options...
s.pratt Posted January 15, 2016 Report Share Posted January 15, 2016 Hello, The relays are internally controlled. Therefore, you should only need to "feed" the common channel with a power source, then connect the output channels to a load. Basically, your common channel is the source of whatever your loads need to run. When the output is "activated", the internal relay will close and feed the power through to your output from the common. Hope this helps. Quote Link to comment Share on other sites More sharing options...
